Serum
Serum's Avatar
03.04.2007, 01:55 PM
if you have another receiver/transmitter, try them..
strodedawg
03.04.2007, 04:43 PM
i have tried everything, maybe the controller isn't reading the motor? i have 5.5 plugs attached - one wire soldered inside and the other soldered to the outside. double wires soldered to the deans plugs and a double wire soldered across the deans plugs. every once and awhile in my attampts the motor beeped and then stopped.
checked crystals used different radios and receivers - all the same result- i bought this sytem about 6 months ago and haven't had the time to set it up until now, due to a back injury.
romster, what were your specific problems?
thanks again for all the help you all have given
let's build something sick!
