03.21.2007, 07:18 PM
@BP-Revo - Here are your measurements:
All measurements are in mm (in case in wasn't obvious ;)) and are pretty accurate +/- 1mm (mostly they are spot-on).
The extra 32mm measurement is how much room between the largest part of the spur to the edge of the chassis. Actually, it is really 33mm, but I figure an extra 1mm for safety is in order. You didn't ask for this, but I assume you would want to know how much battery clearance you have. It looks like it's further out from the spur, but that's just because of the angle of the pic.
The motor mount is all done... except for the adjustment slot (like the stock emaxx mesh adjustment scheme). That's the part I hate because if I slip, the slot is too big, uneven, or just ugly and I have to start all over.
