Borderline at best, though a few guys are using the 60 or 75amp versions in erevos with 4s lipo and 9XLs, so...
hello neil!!
no problem, i bought the 150a version too.....
and i received the 80a version today!!
lookīs great and well built with a great fan,but only for next week will be tested!!!
i donīt know!! but for a "chinese" esc lookīs real good... i only donīt like to see the circuit board being outside the 2 sides of the case!!! hope it donīt break on a rough jumps or backflip...
Well, the Mamba Max has an exposed circuit board, and it seems to hold up fine. I would just make sure that nothing metal could contact the exposed area, and you should be fine.
You're probably thinking of the MMM, which is totally enclosed. The MM has the exposed PCB...
ok, my mistake!! the green mamba ok!!
letīs see how it handles this baby on my e-revo!!!
i will go to a motocross track and if it handles the jumps and falls it will handle the rest.................
The chinese esc looks like a sandwich with the ham poking out either side.. Should be okay, you'd need to really wrench down on the pcbs to snap them off, but it does kinda kill the otherwise clean and beasty look of the esc I must admit.
