Superemaxx89
04.01.2006, 02:35 PM
I'm not interested in ultramaxx as for there is a $99 version coming out shortly that comes with all gears (not just second speed gear). Also, the usage of a second speed gear with a steel idler will ruin the second speed gear, this is why UM used an alloy instead of steel (when they had their first generation set that was to be used with steel idler, they tried to compensate with a teflon hardcoat, but it didn't work, hence gen II).
This braking system works very well. I couldn't ask for anything more. Testing it out yesterday if worked like a charm. However, I am running duel carbon fiber disc brake (what is included is a single fiberglass disc brake, but still works fantastic).
In simple terms, this mod will make your emaxx stop like a tmaxx, which is good.
Rcbros
Rcbros's Avatar
04.03.2006, 07:06 AM
how about an overall picture shot of the whole truck. thanks
  Send a message via Yahoo to Rcbros Send a message via AIM to Rcbros
Superemaxx89
04.03.2006, 05:41 PM
I guess, if that helps:032:
My truck is not done yet though, I just need batteries and esc.
This is the only picture ive got:
rchippie
rchippie's Avatar
04.03.2006, 06:11 PM
That helps some. With your brake setup do you run your tranny with the spur facing the FR or RR of the truck ,
also whos battery straps are the ?. They would work great on my CF racebomb.
REAL MEN RUN BRUSHLESS
Superemaxx89
04.03.2006, 06:52 PM
spur faces the rear
I'm not sure about the second part of your question. But gorillamaxx makes the batt straps (if that is what you are asking)
