10.17.2007, 09:13 PM
"my slippery is too tight"
**must... resist.... urge.... to... make.... crude.... joke....**
Wish I had that problem
Hotti
-Bash till it's broke-
Hotti's Avatar
10.17.2007, 11:49 PM
Yep guys..i drive with stock slippery and the spurs don't last if loosen the slipper that much when it start's to slip.So i have drive with slipper tighten all the way...
With novak i was able to use slipper like the way it's ment to be used but now my system got much more power/torgue..so have to go with tight.
When i manage to get strobe slipper..things will be different.
Emaxx,FLM,Integy,MGM 16018,Maxamps,Lehner 1940/7,Futaba Fasst
10.18.2007, 12:07 PM
Sorry Hotti, I understand what you are saying about the slipper issue, its just that when you said 'slippery is too tight' by mistake instead of 'slipper is too tight', I got a rude picture in my mind....
Hotti
Hotti's Avatar
10.18.2007, 12:22 PM
Show us the picture
10.19.2007, 10:38 AM
Serum would chop me up into little pieces if I posted a suitable picture; hopefully this will suffice:
O ------8
Hotti
Hotti's Avatar
10.19.2007, 11:04 AM
BlackedOutREVO
10.28.2007, 12:34 AM
Originally Posted by Hotti View Post
LMAO!!!!!!!!
Gosh, you guys ALWAYS crack me up!!
Hotti, nice maxx man! And AWESOME place to bash! Nice vid too
Hotti
Hotti's Avatar
10.28.2007, 02:24 AM
Thx mate...
Just got installed those traxxas steel driveshaft's.ALso got other two 2s2p 8000nah maxamps lipos...got four of those now....maybe two more..
BlackedOutREVO
10.28.2007, 11:30 AM
Sweeeeet!
Whens the LMT coming?
Hotti
Hotti's Avatar
10.28.2007, 12:22 PM
German dealer told me friday that he got motor at friday morning and send it to me on friday.Dealer is in Germany and i live in finland..so it probably takes about an week to arrive ..I will tell test result's asap.
BlackedOutREVO
10.28.2007, 12:25 PM
Sweet!
Thing should really rip with the LMT!!
Hotti
Hotti's Avatar
11.01.2007, 04:37 AM
Got it...
The axle doesent have a "place" for pinion screw...how can I make it?
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
11.01.2007, 09:19 AM
nice! looks like you got the regular version and not the hi-amp? did they send the sucker as well? hope that's not an inside joke on their part....
once you can secure the motor and shaft, you can use either a dremel or flat file to get a flat spot on the shaft.
Eflite Blade 400 heli on 3s
Hotti
Hotti's Avatar
11.01.2007, 09:47 AM
Yep..it is normal version...Is the hi-amp version more powerful?
ClodMaxx
ClodMaxx's Avatar
11.01.2007, 10:20 AM
i honestly don't know the difference, other than you'll be able to change the wiring on the back, and you can't with the hi-amp. i have the same motor in a hi-amp, and i've asked what the difference is - other than the wiring options, and that the hi-amp is more expensive - and don't really know if one is more powerful (doubtful) or can handle higher amp loads.
regardless, you have one heck of a motor. it'll put a smile on your face, guaranteed.
are you pairing it with a MM? you should - they work great together. just get a fan to blow on the MM, and you'll be set.
