02.10.2008, 03:57 PM
Well they need to fix the steering servo saver linkage - There is almost no plastic to support the linkage to the turnbuckle
02.27.2008, 06:15 PM
http://www.impaktrc.com/product_info...3ec3518c2d3c4f
They can not be serious! 125 for a steering servo saver - OFNA CNC CRT .5 parts are bonkers prices!
ssspconcepts
ssspconcepts's Avatar
02.27.2008, 06:23 PM
Nope, they lowered the price to $103.
jhautz
jhautz's Avatar
02.27.2008, 06:24 PM
Thats just stupid...
to make it...
or break it...
Silent...But Deadly
cemetery gates
02.27.2008, 09:08 PM
The funny thing is that I broke about 3 stock servo savers(upper one, that attaches to the servo linkage), and its not even the one they make in aluminum! I went so far as to adapt an rc10gt servo saver(complete) and managed to break those too! Right now I have an ofna 9.5 servo saver The part in the lower right of the pic(the one that the servo linkage attaches too) I just drilled out and rounded some edges and now I have no problems!(so far!)
Bye
supralover72
supralover72's Avatar
02.27.2008, 06:21 PM
You can use lusford buckles instead of upper arms. There was a mod on the jammin forum for it. Hope that helps!
02.27.2008, 06:34 PM
It isn't the arms - I break the servo saver - I've just moved to the inner holes and hope that helps... Also slacked off the servo saver a lot...
ssspconcepts
02.27.2008, 08:42 PM
In the pro kit they include a softer servo saver spring...it seems to let the saver do its job much better..
02.27.2008, 06:57 PM
Well to be fair I think I've spend $40 on them now!
jnev
jnev's Avatar
02.27.2008, 07:59 PM
I bet Mike can make one of those for much cheaper.
BlackedOutREVO
02.27.2008, 08:10 PM
I was thinking the same
rschoi_75
Certified Spaceball
rschoi_75's Avatar
02.27.2008, 08:30 PM
wow... that price is ridiculous. And I thought the price for the cnc hubs were high...
rcm xt8
rcm xb8
rcm crt.5
ssspconcepts
02.27.2008, 09:21 PM
Yep...almost as much as a UE Supermaxx servo saver...if you could still buy them.
GO-RIDE.com
02.27.2008, 09:38 PM
Man I've broken a bunch (at least 6) of lower front arms and a couple of upper arm turnbuckles and only one servo saver part. When I broke the servo saver I thought it was just a fluke. I got rear ended by a MT at the track and it smashed me straight into a wall. I actually run the stiffer saver spring (with a full sized servo) because the softer one was too soft and I was getting bump steer.
What I wish they would do is offer some of the parts by themselves. I'd like to buy just front arms for $6 instead for F & R for $10. Does anyone want to trade 2 front lower arms for 6 rear lower arms? I have 6 rears and need more fronts.
I've also broken a few body mounts. It's a joke to spend $10 for a bunch of other parts just to get the body mounts. And what about the upper arms that are $10 because they come on a parts tree with parts that never break?
Luckily I love the way the E-crt.5 drives both in the backyard and at the track. It's a blast cutting under 1/8 scales on every tight turn.
E-8ight - Tekin RX8 2000kv/4S
02.27.2008, 09:55 PM
I fixed the body mount issue by using cut down traxxas pede ones - $4... Just cut them off and drill a hole through them...
