Rivermaxx
03.06.2012, 03:03 PM
Originally Posted by RootzMan View Post
There was another guy who persuaded John's BSR to make up a set of big foams for his E-Maxx. They were narrower than mine and cost him a whole lot without much success.
That happens to be me I broke the current open wheel world record for that year(2009) and probably still the fastest e-maxx around so "not much success" is your opinion. How fast is your erevo on 6s? Id really like to know Vid or proof would be appreciated. Btw There was no other option for tires back then bsr made them for ~150 and told me to run them narrow. Should of made them wide or used traction compound because traction after 70 mph on that dirty track sucked for foam tires. Sorry for post digging but needed to defend my car lol.
RootzMan
RootzMan's Avatar
04.07.2012, 05:45 PM
I am really sorry, Rivermaxx. My memory isn't as good as I thought. Please accept my sincerest apologies.
My Revo never fulfilled its promise, I'm afraid and is now enjoying a well-earned retirement with a Ballistic 8 and an RX8. It wasn't for want of power, grip or aero. My set-up skills were the real let-down. It was nigh-on undriveable. If you fancy a gander, here it is...
http://www.youtube.com/watch?v=w2p3IYbNms0
You live and learn!
Cheerz!
Rootz
Cheerz!
Rootz
www.fast-rc.co.uk
roost
12.03.2011, 08:27 PM
Some data log of a Lehner 2240/7 on 6s pushing a savage xl around. Anyone else got Graphs? im interested in seeing what other motors on 6s put out
12.04.2011, 09:22 PM
Man, you guys are really sh!tting in this thread....
I did some speed runs in a revo a few years back. My setup was bl with stock suspension and I was using the revo to test the effect of wheel balancing and tire taping.
My conclusions were as follows:
An unbalanced tire is a bad idea, especially if it is not taped either. Even at 60mph the out of balance condition was causing enough force to compress the suspension to its upward travel limit and let the tire leave the ground.
Taping helped, but balancing was the only way to get the vehicle to track smoothly. Pretty sure I was running a 1515 1d on 4s, geared high enough to get over 60mph with properly taped an balanced tires that would not grow (keep in mind tire growth increases the rollout, so you will go farther per tire revolution, thus faster top speed.)
Pretty sure the 1521 wil be the longest can motor that will fit an ervo with mods. I think 1521 on 6s with a sutable kv to do 45k - 50k rpm max with the correct gearing will be the best bet to get up to 100mph. Airflow mgmt will be critical, and I think a tire around 1.5" wide will be about right.
Limiting the suspension travel to the minimun you can get away with is critical. 1/2 inch of travel at the tire and a very smooth survace will yeild the best result.
I like the body you have rootzman, keeping air out of under the body is a good idea. You can cut the back out to aid air extraction as well.
RootzMan
RootzMan's Avatar
12.05.2011, 06:52 AM
My conclusion too. I seem to remember that, in order to fit it, I had to shave down the motor mount and grind the shaft down too. Then, with the gearing I was running, I had to accommodate a lower position for the motor. That was only possible by modifying the rear shock mount.
Not sure I'd agree with 1 1/2" wide tyres. That just seems a tad narrow to me.
Here's a body style I mocked up but never got further. If I were to go back to speed running my E-Revo, I think I may well take this route.
Cheerz!
Rootz
www.fast-rc.co.uk
RRHobbydepot
04.07.2012, 12:17 AM
Any new updates? How r u keeping the front end down? I keep having unloading issues on both my personal vehicles.
Rick's Radical Hobby Depot For all your R/C needs!
