First look at the single speed E-Maxx conversion kit
gorillamaxx
gorillamaxx's Avatar
First look at the single speed E-Maxx conversion kit - 03.19.2005, 12:02 AM
Here’s a first look at the transmission kit. This is still a prototype. I’m working on some fine tuning for alignment of the gears. Mike should be getting his soon for testing.
The design uses the back half of the stock case and the rear set of gears. The only mod you’ll need to do is cutting the front end off the upper drive shaft (a metal hand saw or dremel takes care of it quite easily). The key to the design is the round coupler piece that sets into the second gear and locks down the drive output shaft. It replaces the inside bearing. All other parts fit from the stock kit. It’s fairly simple and considering all those extra parts you’ll lose off your truck and the rock solid gear meshing this should be a good addition to your race truck.
Let me know what you guys think.
