AAngel
04.17.2007, 04:54 PM
Brian,
Believe it or not, I tend to like to over engineer things myself. I also like to avoid the hotter setups, just because I'd rather have something dependable than a bit faster. All in all, my biggest problems have been with controllers. Obviously, the MM is doing fine in the light buggy on 4S, but the MM also leaves something to be desired in the truck arena.
I'm not having any problems with my mounts, gears, batteries, etc.
Anyway, what are you running? It seems to be working for you.
I'm going to pull another MM and wire it up with 12 gauge and for the bec and get my neglected buggy up to par. I'll just stick with that for a while, until I can get my Muggy back up and in its right form.
