04.18.2007, 10:18 AM
The trouble is if CC tells us the "real" limitations, then some people will simply push it further still. It's bad enough now when the limits are fairly low! And really, the limits are pretty much already stated; 4s, 100A. It's up to the user to use a motor combo that falls withing that guideline.
Some of the problem with the MM has to be programming, simply because of the commonality of parts with the Quark. MetalMan did mention maybe installing some new/larger caps on the ESC, which would probably help.
As to a "proper" setup: A MM running maximum of 4s, in a 10th scale vehicle, around 5 lbs, with the 4600, 5700, 6900, or 7700 motor. ;)
