Procharged5.0
Procharged5.0's Avatar
04.18.2007, 12:03 PM
Originally Posted by Serum
I doubt if neu made them, they are available from several other sources.
These plugs are not the way to go. they get loose from time to time, the material deforms. While the 4mm plugs use a spring kind of thing to keep in place, this is just solid metal (brass type of stuff, not known for its flexibility.)
While they might look nice and are good for static use.. they can't stand too much abuse. If you want a good plug, get powerpoles. they are great. Too bad Deans doesn't make a 3pole plug.. they should make their plugs about 1.3 times the size they now have. That would be great IMO.
They are on the NEU website. They are a NEU product. However I can't guarantee that they manufactured them however.
