bdebde
That's All Folks!
bdebde's Avatar
04.25.2007, 11:02 AM
***RC***: Have not run it too much for top speed, gotta be about 45 i think.
AAngel: not sure what you mean about the bearing standoff? I did have a problem witth the screw heads not quite being flush with the spur. Ended up putting a diff shim on the outside of the rear bearing to get the screw heads away from the diff mount.
I am running 14/46 gearing right now, may go down to 12. Still gotta see what run times are like. I may get an 8XL as well just to give it try. Never hurts to have a extra motor, or different ones for different tracks
