gearing on hv maxx -
04.25.2007, 11:11 AM
hey guys, one last question about the hv maxx. what type of gearing should i run, il have the single speed on her soon, and its only 2 wheel drive, i was running 12/72 last time then ran 17/72 for abit, if im gona change somthing i rather change my pinion, cause i got quite a few 72t spurs.
04.25.2007, 12:49 PM
On a two wheel drive maxx, not sure, but the HV comes with gearing reccomendations. I would run 11/72
BMW M Power!
04.25.2007, 08:57 PM
I'd go with a 14 or 15T pinion. I generally ran 14T with my 4wd G2R.
04.26.2007, 08:58 AM
I would get fans in that case.
hold my beer... watch this...
04.26.2007, 10:04 AM
i agree with newe.
even if you're running a 72t spur, a 15t pinion is pushing it. there have been too many stories of the hv system blowing with overgearing. i'm not taking any chances at all, and am running 70/12... which on a light truck could be undergeared (my motor was running about 140 degrees and the ESC was only about 85) but have since added a LOT of aluminum.
whatever gearing you use, just monitor your temps closely with a temp gun.
BMW M Power!
04.26.2007, 10:39 AM
I was running a 14T pinion on my G2R under race conditions and it was holding up without a hitch. I'm sure he can get away with a 15T since he has 2wd. You'd be suprised how much strain that takes off...
