zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.26.2007, 04:12 PM
Originally Posted by Finnster
Could be the shift servo is not quite lined up as well. WhenI 1st got my Emaxx, it had a JR radio, and would not shift past neutral until I adj the set points and throw. Just have to investigate.
Glad you like it so far, wait until you get into 2nd, and even run on 14 cells or 4S lipos. :)
True, it could be that too, like maybe the rod is not pushing far enough, to give it enough pressure to pop it into 2nd gear?
