Finnster
KillaHurtz
Finnster's Avatar
04.27.2007, 10:32 AM
Originally Posted by t-maxxracer32
ok so after looking over it for about 15 min i dont get it at all lol... its peice a total peice of shit and now i cant even get it to work in first (i am in a bad mood right now cause i cannot fix it)
anyways there are 2 metal pinion like things in the tranny. are they both supposed to have little allen screws holding them in place? because the second gear (or the one in the back) spins freely. i think that is what is causing the problem.
lmk if that might be it
thanks
:010:
If I understand what you are saying, it sounds like the roll pin for the top gear ("2 metal pinion like things in the tranny") for 2nd gear broke. This is a common occurance. Zero(IIRC) has a thread just below on this problem and a few diff solns. Basically you need to put a new pin in place to lock the "pinion" onto the top gear shaft. Some use 2mm hex keys, some use drill bit shafts, etc. Its a simple fix.
You can lock the tranny in 2nd w/o having to spend any money. Just remove the 1st gear idler and shift fork, and lock the dog carrier to the 2nd gear dog gear. I used 3mm screws. BrianG has a thread in the Revo section IIRC that illustrates this. For a fancier fix, you can just get the Gmaxx single speed kit from Mike.
1st gear is a waste w/ BL, so its recc either way. In stock fashion, the dog carrier engages the dog gear and slams the driveline as it can spin nearly 180* before the 2 tabs engage. Its does this every time you shift, and everytime you go to from Forward to Brake/Rev and vice versa. This is biggest contributor to Emaxx trashing diffs problems IMO.
