ssspconcepts
ssspconcepts's Avatar
05.02.2007, 10:26 PM
Originally Posted by Serum
You do need longer hingepins with them i pressume?
The timaxx i am building hasn't seen any track/road.. i was waitin for some parts, and now it's on the 3rd place of projects to finish.. Too bad..
The RPM knuckles are okay though, installing the retainer takes some patience. they are tight.
There are no alternatives IMO. i tried buggy knuckles, but no succes. Integy knuckles are not considered an alternative. UE doesn't make the right knuckles anymore.. The only possible neat option i can think of is using Revo 3.3 shafts with rd-racing knuckles . (not too expensive either, 99 for 4 of them)
Actually I used the hinge pins that came with the FLM hybrid bulks. Longer pins would have gotten in the way of the servo saver. However, I did have to grind/shave off the collar to the plastic FXT A-arm bushing...I just needed like .05mm to make the hinge pin fit and that did the trick.
I used integy knuckles on my 1st monster truck...that was the straw that broke the camel's back...I'll never buy their products again. I know golden horizon makes some, but I wanted oversized bearings.
