05.03.2007, 12:28 PM
^^^ +1. Really, man - where ARE your priorities?!
05.03.2007, 12:31 PM
I couldn't believe what i was reading either.. Speaking of which.. I've got a hellfire to build!
05.03.2007, 12:36 PM
I really think you ought to finish your e-Revo first. ;)
05.03.2007, 12:42 PM
A couple of weeks to install a few cupboards.... drink 10 cans of redbull and take a packet of pro-plus; you'll be finished in an hour!
05.03.2007, 02:11 PM
Too funny..
To be honest, the revo is nearly finished.. but that's not the only truck that's waiting to be finished.. the hellfire is screaming my name at this moment, i think i need to obey..
05.03.2007, 02:46 PM
Well, since my wife is so understanding about RC, the least I can do is install the new kitchen. I could probably do it in 3 or 4 days, but I have that darn job thing to worry about too. I also have to gut and paint the kitchen before the new stuff can go in. Don't worry though, my OCD will kick in and the E-Revo will be breathing fire before you know it!
05.03.2007, 02:48 PM
Ah, the wife.... I understand now. And jobs, those get in the way of our fun alot too.... Never mind eh, something to look forward.
05.03.2007, 03:07 PM
Ok, I have a question right off the bat. The motor didn't come with any mounting screws, what size should I use? I don't want to screw up my brand new motor by using screws that are too long.
Thanks guys!
Cajun
05.03.2007, 03:29 PM
3mm diameter, but the length depends on how thick them mount is, and whether you use the RCM heatsink/clamp (it adds ~1.5mm thickness). I usually turn the screw very gently into the unmounted motor and when it touches a coil, back off 3 or 4 turns. That'll tell you how deep to go.
05.03.2007, 03:37 PM
Thanks, I can figure it out from there. I will be using Mike's mount and heatsink, so I'll figure out what to add for those.
05.03.2007, 08:58 PM
05.03.2007, 09:10 PM
Good job man! That's a very different setup!
What did you end up doing with the tranny (lock into second, keep 2 speed, etc)? Also, is that Hammered finish paint I see? I love that stuff - it makes a nice hard finish.
05.03.2007, 09:24 PM
Thanks Brian! The idea was to get it as compact as possible. I want to be able to use a stock body without it being pushed out. The batt tray should accompdate up to 16 cells. The only drawback to the configuration I see is that I'm going to have to lengthen the ESC to motor leads by a few inches.
I locked the tranny into 2nd using your method. That is Rustoleum Hammered finish paint. I love that stuff too, nice and hard plus it hides all the imperfections better than any other spray paint I've found.
I have a couple of little things coming from Tower to finish the setup, then I'll be ready to run.
05.03.2007, 09:30 PM
Yeah, hiding imperfections is a "good" thing. :)
A little tip: So you don't need to use as much of the more expensive hammered paint (or multiple layers) to cover the pinholes, spray a thin coating of flat black metal paint first, let dry for 10-15 minutes, and then go over with a thin layer of the hammered stuff. Seems to work better than primer, covers pinholes much easier, and is more chip resistant for some reason. BTW: Your paint job looks fine, this is just for future reference.
05.03.2007, 09:34 PM
looks great, wish mine came together so quickly, will you be testing this wkend or next
