Pinion on a 5mm shaft.. is there a trick?
Trick440
Pinion on a 5mm shaft.. is there a trick? - 05.03.2007, 02:20 PM
Ok I tried putting a pinion gear on my Nue motor 5mm shaft...
I think the pinion set screw threads where messed up already... I was just screwing it in not evenb tightening it and the treads came out.
What should I do when I get a new pinion.... should I grind a flat spot on the 5mm shaft so the set scre can screw in more?
This sucks cause I wanna try this thing!!!!!!!!!
