It might help a little since if the springs are to weak in the rear the rear will squat and let the front balloon. It's really a game of trial and error.
thanks ill just keep trying diff things and enjoy the fact that its finally running, on the bright side i have no spur gear wear, i was a little nervous about it cause if my mount was off to much it would probably eat gears
well i ran about 20 min today with 300k in the front diff it helped alot, anyway just wanted to post temps, 100f on the batterys, 105 on the motor and after 3 speed runs the esc got up to 135f so looks like its ok, may go to wide ratio on the 2 spd
i think im done with the center diff in the stock trans. it just will not distribute power like i want just a fyi for those of you who want to try this set up , i think it sucks,lol, but i think many of you probaly new that, any way after a little track time today i think i need to get rid of the center diff, but may go with the slipperentual
