smhertzog
Breaker of all that is Stock
smhertzog's Avatar
05.06.2007, 08:42 AM
A word of warning, I had an emaxx with with the motor mounted from the front of the can and an additional attachment point, two 4mm bolts through slots in the body and into a threaded motor heat sink. It worked very well even dropped my engine temp a little. But after a few weeks I noticed the front bell was loose, when I unbolted the rear mounting bolts the can just spun around on the bell. If not for the magnet it would have slid off easily. The mounting points spanned an area of the chssis that flexed. Your motor looks very close to the chassis plate. If it flexes and contacts your motor it might get ugly. CRTs are none to flex alot in that area. Then again maybe its just the picture angle.
Never fight an ugly man..... he has nothing to loose
