05.06.2007, 09:46 AM
smhertzog, Thanks for the warning. I was planing on putting a clamp from the end of the motor back to the motor mounting plate to help keep the motor together on landing s from jumping. The motor has about 2 mm of clearance to the chassie. Do you think that is enough? :032:
Thanks to all for you compliments!:o
RC, I will let you know on the run times and the heat, I havent got to run it enough yet to tell.
