cemetery gates
05.07.2007, 04:57 PM
Brian, are you running the traxxas center diff? If so, what weight oil are you running? In my revo the stock 100k was not enough so I went to 120k. That was not enough; front tires kept unloading massively, like I had 10k oil. So then the only thing I could think of that would be better was... umm.... Silly Putty! I really packed the diff with it and it worked great... for about half a battery pack(8000mAh).
I was really fed up so I packed the diff with JB weld. I am pretty sure that will hold(no diff action). Have you had better luck? What would you suggest I do?
Thanks
Bye:018:
