zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.09.2007, 03:03 PM
I would play with it a bit before you take it apart. IMO
YES! That is almost exactly what I was thinking, sandwiching it between two slabs with screws, then another case. Seeing as doing the internal mod works wonders, a custom case with no transfer slab, and a being able to transfer heat away from the top FET's will make it a new esc, plus more caps. It would be a hellova controller.
