green24
05.11.2007, 09:05 PM
Should be a cool conversion. But what are you going to do about pinion/spur engagement? Isn't the pinion inside the tranny with a dogbone hooked up to the clutch? Also, for battery mounting, maybe you could mount 2 packs next to the dogbone UNDER the chassis, and cut out some of the bottom brace to make it fit. Then make a new brace and skid plate to protect it.
