GriffinRU
05.13.2007, 08:39 PM
Originally Posted by zeropointbug
Are you sure that can be done Artur? Aren't the brains meant specifically for driving a certain FET?
What kind of package are you thinking? At the present time, is it better to use larger FET's (fewer), or more of a smaller FET?
Everything is possible, you can intercept signal and build output stage anyway you want. Looking at volume below 100 units there is no benefits in using smaller FET's but after testing it would be clear. In my opinion less components always more reliable and easy to fix.
