Update
darkshadow587
Update - 05.17.2007, 02:09 PM
just thought i would post an update of my project. its coming along ok. ran into one problem. i'm running a low tooth pinion so the motor hit the rear chassis brace when i tried to mesh it together. i have the cnc aluminum chassis braces, i'm just going to use the dremel and grind it down to about half thickness. it looks like the going to work out good so far.
