you can see that the arm is thinner and has had material removed. You want to take a dremel + drumsander attachment and carefully remove some material in the areas I've circled. Go easy though as you dont need to remove much- test fit one set of A-arms and if need be remove a tiny bit more, then just repeat the process with all the A-arms.
