bdebde
That's All Folks!
bdebde's Avatar
05.18.2007, 12:02 AM
The Mamba Max motors should work fine in a Jato. The 7700 would be the fastest if you were running 7 cells, although it may run a bit hot. Set motor timing to lowest to help. The 5700 was respectable on 6 cells in my MT2 (heavier than Jato and 4wd) before I went 3s lipo on it.
