MetalMan
MetalMan's Avatar
05.20.2007, 09:09 PM
Here's an idea - if you want to go the same speed when switching to 5s as you had with 4s, use a pinion that is four-fifths the size of the one you are using with 4s. So, 16 x 4/5 = 12.8. You could use a 13t pinion.
