05.22.2007, 08:01 PM
Then to permanently keep the fan internals in there place use electrical grade epoxy. I yellowed the area in the pic to apply the epoxy. Then also put a little epoxy on the electrical components that stick up on the green PCB board. keep in mind you don't want epoxy oozing out everywhere because it will lock up the fan. Route the wires back were they go. Then press the fan back together. Set it to dry so that if any epoxy oozes out it doesn't drip on the fan blades (in other words, fan blades up, glue side down).
I have had really good results with doing this and I'm sure you will too!
