AAngel
05.23.2007, 04:47 PM
I've seen a couple of dual motor and dual engine setups. No doubt that when setup right, they perform very well, but never as well as you'd hope they would. Of course, I haven't seen/done everything. I'd love to be proven wrong. It would give me an excuse to venture into a place that I've never, personally, been before.
The real downside is the return on investment. Figure two MM systems at about $400. For the price of a MM esc and Feigao motor, you could still have money left over for a lipo pack and it will probably run as fast or faster than the dual motor setup.
Again, I'd really love to be proven wrong.
Procharged5.0
Procharged5.0's Avatar
05.23.2007, 05:06 PM
I'd have to agree. I also like the simplicity of the single set-up. Let weight, less wiring, less maintenance, etc.
05.23.2007, 05:24 PM
OK, say I can be convinced to run a single motor....what is the name of this motor?
Serum
Serum's Avatar
05.23.2007, 04:52 PM
Sorry, a small rectification;
The XL motor of the lehner Basic are not 1/10th motors, they are larger; they however don't use segmented magnets.
the more expensive series of Lehner (1920/1930/1940 etc) do use segmented magnets.
Here is a link to the Neu motors; (made in the US btw)
http://www.rc-monster.com/proddetail...091.5ys&cat=20
This is not the KV i recommend (unless you want a REAL powerhouse) but you can shoot Mike an email about the other KV values; 1800-2000kv would be nice for 4S.
Here is the manufacturers link;
http://www.neumotors.com
Procharged5.0
05.23.2007, 05:29 PM
The most trouble free of the single motor combos would be a Lehner 1940/9 with a Mamba Max ESC.
The NEU 1515 is a better motor than the Lehner but works better with a Quark 125b ESC than a Mamba Max.
steveo
05.23.2007, 05:35 PM
those motors are plettenberg big maxximum
Procharged5.0
05.23.2007, 05:39 PM
Sorry, I missed the question (or just mis-read it)
You don't want a BIG-MAXXIMUM. They look really cool, but there are better and more efficient motors available.
Serum
Serum's Avatar
05.24.2007, 01:43 AM
Going dual 1940 or 1515 is simple too much. IIRC you want a lightweight setup, go for smaller motors.
BP-Revo
BMW M Power!
BP-Revo's Avatar
05.24.2007, 02:00 AM
I'd say dual 1930's with Mamba Max ESC's running off of 4S each. Should be plenty powerful :)
starscream
RC-Monster TQ
starscream's Avatar
05.24.2007, 03:50 AM
WOW... two plett's, I wish I had one :017:
Well, I guess two motors may seem asthetically pleasing but its functionally un-neccessary and un-warranted. Besides, what does asthetics matter when the body cover's everything up?
Two BL systems will increase a few things though. They will increase the initial cost, increase the maintenance, increase the weight, and increase the possible failure points. The one thing it won't increase is the performance.
A single motor setup will simply out perform a dual motor setup any day of the week
Ha Ha
jhautz
jhautz's Avatar
05.24.2007, 03:53 AM
I agree w/ serum... dual motor setup is not an ideal solution IMO. It adds a ton of complexity to the whole setup, not to mention weight and wires all over the place. It will look like a very symmetrical spaghetti bowl :005:
A simple, clean setup can be a very beautiful thing as well. I would focus more on quality than quantity.
If you are looking at Lehner motors, the 1940 is more than enough in single format. Dual 1940's would do nothing except shred gears. Cant go very fast with shreded gears.
to make it...
or break it...
Silent...But Deadly
Dafni
Dafni's Avatar
05.24.2007, 05:41 AM
I agree with Starscream and Jhautz.
I take simplicity over symetry any day. But I never understood this shelf queen thing anyway.
And with no gain in performance, the decision is obvious to me.
Efficiency is the most important factor when you want to actually run your BL truck.
Gustav
Gustav's Avatar
05.24.2007, 07:31 AM
all true,but,on the other hand,two MM escs can handle twice the power of one,and since there's a shortage of high power controllers,sharing the work load between two doesn't seem like the worst idea.
Serum
Serum's Avatar
05.24.2007, 08:54 AM
Gustav; One mm controller can take the maxximum power from a lipo pack, at a more efficient factor than a dual setup.
Dual is a nono for me. (as well as for other users) but if 0700 wants a dual setup, we need to advise him what we think is best.
Gustav
Gustav's Avatar
05.24.2007, 12:47 PM
Yeah,i know,dual is not something i'd do either,ideally, but i can see a case for it,sort of.It's hard to recommend a 6-8s controller at the moment,that's why.
You'd have to have some hot motor on 4s to keep up with a pair of milder systems on 4s,closes the efficiency gap a little if you're chasing a certain amount of power,at least it won't thermal.Also,using a pair of cheaper,lighter 4s packs,since you'd be taking less current from each,helps some with the cost and weight difference.So say you're taking 70% of the amps each,from a pair of 4s packs,that you'd be taking from a single,more powerful 4s pack with a single big motor and single esc,you'd still be up on power whilst being down on temperature and load on each esc..
So i'd take it over running a single mega hot motor,although it's not ideal,going higher voltage with a single system is.Me personally,i'm building everything light these days so i can run cool 4s setups (single),35mph is enough for me,i just want a cool running,hassle free setup that is nice to drive and has plenty of snap.the novelty of running huge power up and down in straight lines wears off,then you just want to get on with driving.until some alternative high voltage controllers come along,then i might build some big monsters again.
0700,do you have an idea what you want to spend? and if you want to make them useable as single systems in other applications?
