cemetery gates
05.23.2007, 07:15 PM
Originally Posted by BrianG
Not necessarily. The key to long-lasting pinion is a solid and consistent mesh. Both Mike and I (and maybe others) have run steel on steel with very good results. I've run my Hyper8 for about 10-12 packs' worth and the pinion still looks very good. The only downside to steel pinions is the cost compared to regular pinions.
Yes, I know that, but not everyone has got the money for hardened steel pinions and can achieve an absolutely perfect and consistent mesh.
@rchippie
- you would only need the ring and pinion gears, not complete diffs....
Bye:018:
*EDIT* Brian, actually when I had a dual HV-maxx e-maxx I ran a RRP 65t hardened steel spur with kyosho pinions and had no ill effects at all over many, many runs. But, when I put RRP pinions on (just to change ratio) the pinions lasted maybe 3 runs at most. Weird:confused:
