IBJAMMIN
IBJAMMIN's Avatar
05.23.2007, 09:15 PM
If you want to get your BL CRT.5 conversion going get a hardened pinion and from the looks of it they should hold up with the steel spur till the new spurs do come out. Depending on the motor your going to run there is a few hardened pinion choices avalible. :)
