05.23.2007, 10:00 PM
It takes X amount of power to move any vehicle at a decent acceleration. Power is volts*current. So, for less voltage, you need more current. High currents cause thigs to heat up and is inefficient due to voltage drops, more heat, etc. So, using higher voltage lets you get high power with less current and things heat up less and everything is more efficient.
