starscream
RC-Monster TQ
starscream's Avatar
05.26.2007, 03:19 AM
Originally Posted by jhautz
6s is more voltage than I want. The controller wont handle 7s or 8s and even if I did have a controller and motor suitable for 7 or 8s It would defeat the purpouse of going to a light setup. I might as well just use the motor and controller I already have and run 4s2p. Same weight and cell count. Besides that... 7 or 8s is just way more voltage than needed IMO.
4s lipo should be more than enough voltage for racing, and for me the voltage of the 4s A123 is enough for the track. I'm just wondering if thet can handle the amp draw at 1p.
Maybe I'm misunderstanding what you mean????
I've never run these cells in parrallel so my point is that if you're worried about weight then 4s2p would be the best formula for you. You simply won't get much power with 4s1p due to the voltage drop. 4s2p will probably get you a little over 10 minutes on the track (race conditions) with enough power for you MT to effectively compete.
Ha Ha
