05.27.2007, 10:55 AM
If you can get a donar Revo then you can just remove the front & rear sections, and sell everything else to recoup alot of the cost. Buying all the parts to build the front & rear would be a nightmare as there are so many small bits and pieces... gah, no.
The V2 slipperential is a straight swap for the emaxx tranny, and use no tranny parts what-so ever. Its lighter, stronger and generally much better for racing due to the better gears (mod 1 pitch), and tune-abilty.
For 12cells, I would recommend the MM and a 8 or 9XL- though wait for some second opinions on that one.
Welcome to the forum, we hope you enjoy your stay.
pullstarter
Pullstarter
05.28.2007, 05:08 AM
Thanks for the help buddy. An MM esc is a mamba maxx i assume? They can handle the power of a bigger can motor ok? Also does the V2 come with a cover? Seems a bit exposed in the pics i've seen. BTW my parents come from somerset so "oh arr" to you :005: Thanks again for the help. :028:
