Originally Posted by zeropointbug
So what do you mean, is it fried then?
I will only accept it if it is non-usable to you. Thanks in advance! :027:
Fried, chewed up a little, missing parts. It came loose from the chassis of my 8ight, right after I removed ALL of its case (reckless of me), and was killed by the spur gear. After it died, I used it as a guide to figure out how I was going to do mods on its replacement. (I wanted to add caps to the board, and repair the faulty inner FETs heat sink design, and found where the two 'boards' seperate making it a lot easier.)
I'm done tinkering with it, and threw it into my broken parts box. Its missing 1 cap, the on/off switch, and both heat sinks. (heat batteries is more like it)
I have the case, and 2 sets of end covers as well if you need these. Let me know.
I use UPS, they go up north dont they? If not, I think its small enough for U.S. Mail. E-Me and let me know, I'd be more then happy to ship it to you.
The info in this thread was well worth it, and I may want to be on the list for your after market case too.....:027:
