MikeyLikesItSI
05.31.2007, 08:54 PM
Brian thanks for the quick response and insight. I must say the reason for my gear ratio was to try to over come the cogging issue. I figured larger pinions (which if i read your response correctly, would help reduce heat from the motor) would make it cog worse since it required more torque to turn the driveline
T-MAXX - MGM 16016 - Neu 1515 1Y - 2x 6000mah 2s2p
RC10TC4 - MGM 8012 - C.C. 540 5700kv
Mini-Quake - C.C. Mamba Competition Package - 2s 1450mah
RC10T - Novak Super Stock BL setup
