Brake fade?
bdebde
That's All Folks!
bdebde's Avatar
Brake fade? - 06.01.2007, 12:46 AM
I was doin a little parking lot bashing with my buggy today, with a new set of road rages on it. After running a while, the brakes seemed to "fade". I cranked up the brakes on the radio from 75% to 100% but that only helped a bit. Normally, at 100% the wheels lock up, even sometimes at 75% if it's a bit dusty. I have the brakes set to 75% (*edit: it is only set at 50%*) in the mamba settings. I think it may be running a bit hotter now as well, not sure as I was about done with that pack. I did try it again later after charging the battery again, but still kinda soft brakes. I am going to doublecheck the settings again and see if any difference there.
So, do you think I lost a fet or 2. I suppose the brake fets are not connected to the heatsink (anybody know?)? I am just getting this rig dialed in and hate to send the Mamba off for repair now. Guess I better get a spare Mamba just to have around (have em in 3 rigs).
bdebde
That's All Folks!
bdebde's Avatar
06.01.2007, 03:16 PM
Any Ideas anybody? Do you think this may be cap related instead of fet related? Guess I could put some caps on it to see.
nativepaul
nativepaul's Avatar
06.01.2007, 03:19 PM
I have a buggy with 8XL, MM, 12 nicads and road rages,
I have noticed no brake fade but I get only 10 min runs so maybe I'm not running long enough to fade.
I'm not running a track, just road bashing so its possible that i'm getting some Very minor fade but not noticeing, it will still lock em up all through a run tho.
What buggy is it? I set my MM brakes to 30% on the MM it will lock the lightest tyre, 40% locked all 4 road rages on my lightning 2 pro at 8lb 12oz.
Whats the temp on the MM? When I changed from the factory MM brake settings to 30% I stoped locking all the tyres, my braking distances got much shorter and my MM got about 10-15deg C hotter, maybe if your allready hovering just under the overtemp cutoff point at the end of a run it wont brake hard and push itself over the edge into thermal shutdown.
bdebde
That's All Folks!
bdebde's Avatar
06.01.2007, 03:29 PM
I also let it cool off and tried it again later, but the brakes did not come back to normal. Had Mamba set at 50% with radio at 75% (37.5% total) and it would lock em up with most tires. I tried setting the brakes up to 75% now on the Mamba, and it stops good, but still won't lock em up. I haven't got the temp probe out to check actual temps, but it was normally only warm to the touch, now it is hot to the touch (no thermals that I could tell). Buggy is Sportwerks Mayhem.
*edit: also noticed some cogging at low start speeds now, used to be real smooth.*
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.01.2007, 04:05 PM
I had a similar problem with 2 MM ESC's. It was smooth, braked hard and I was bragging left and right. Then slowly the brakes faded and I got less power. Cogging would get worse and then one day ....BOOOM!!...ESC smoked. I'm still waiting for my replacement ESC from CC. Brake was always set 50% and drag brake was at 10%. My last ESC blew all 3 caps. And I'm running a fan on my ESC too, making me wonder about the qaulity. My buddy has his ESC since last year and still going with the exact same setup that I have.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
nativepaul
nativepaul's Avatar
06.01.2007, 06:21 PM
Hmm I didn't think of the drag brake, but that could have a very big effect, I spend a lot more time rolling round corners off the throttle than I do with the brakes on.
If it is still faded after a rest then it is not temps like I originaly thought.
My MM has always had occasional but pretty severe cogging at low speed, I hardwired my motor, but my batterys are old and crap so I think they just can't supply the juice needed.
I hope you get to the bottom of it in the end, keep us posted.
bdebde
That's All Folks!
bdebde's Avatar
06.04.2007, 11:02 AM
Update here- The trusty Mamba Max is FINE! Turns out my 8XL burned up and it is only a week old. I put my 7XL back in it and all is working fine. I still had the brakes cranked up and nearly flipped. I guess it may be time to get a more efficient motor.
06.04.2007, 01:12 PM
Until CC gets the software update for the MM to run Neus, that leaves the Lehner motors. Unless you can deal with the cogging...
bdebde
That's All Folks!
bdebde's Avatar
06.04.2007, 03:10 PM
I hate cogging! I wonder if a Plettenberg bigmaxx would work with the mamba? Can't seem to find lehners anywhere, and I have been looking for a while.
