zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.08.2007, 03:40 PM
Yes, I had the narrow neutral range as well, that's why.
AAngel, my FET heat spreader was the very same as that! It was only touching half of the FET's, and the PCB moved around easy (slack). But I am thinking that the caps leads being GONE had something to do with it starting on fire.
Are you sure you don't want to wait for my custom quark case for yours? If not, maybe you should epoxy the top FET heat spreader as well, to increase thermal conductivity (power spikes).
I also received the 30 caps this morning, I have the day off so I will see what I can do for a cap bank.:)
Let me know if you are going to do as far as the 'mod', or if you might want my case.
