zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.08.2007, 07:32 PM
oh, you already applied it... then yes use 99% alcohol then with a cotton swab, or Q-tip, and get it clean, clean, clean. Keep rubbing until your cotton swab (keep replacing with clean one) is clear and NO sign of grey in it. Try and not get anything onto the FET's pins.
I am going to clean out my quark case and use it as the cap bank, and maybe use some AA i have to attach it to the case, if not CA glue.
I can't find any copper buss bar or anything, and I guess you can't really solder to aluminum, I might have to use 12Ga wire then. I am going to use 6 caps.
