Serum
Serum's Avatar
06.09.2007, 02:46 AM
Interesting Daf;
Have you played with chamfer/caster/toe in? front/rear?
weight ballance?
Things for more traction in corners;
softer anti-rol bar
more toe-in
less possitive camber in front gives you less grip in front
more possitive rear camber gives you less change of traction rolling
Less (smaller angle) caster in front gives you less steering
Dafni
Dafni's Avatar
06.09.2007, 03:14 AM
Originally Posted by Serum
Interesting Daf;
weight ballance?
softer anti-rol bar
more toe-in
I tried different diff oils, sway bars and everything.
But thank you anyway
Daf
Dafni
Dafni's Avatar
06.09.2007, 12:14 PM
Okay, today was much better! I think one of my problems were worn down rear tires.
I switched back to a thinner rear sway bar and a lighter oil in the front diff. Now it's pretty good. It was easy to drive today, the track was very loose.
