Serum
Serum's Avatar
06.10.2007, 02:46 PM
But the statisfaction of the magnet is reached pretty soon on the hvmaxx.
It's got a tiny 12mm rotor;
You said a hvmaxx was more efficient than an XL;
but that's quite familiar on partial load with segmented/sintered magnets;
Did you take this into consideration;?
a 1000 watt setup at 93% eff. gets 70 watts of heat;
a 1500 watt setup at 95% eff. gets 75 watts of heat; while the 1500 watt setup is more efficient, though it will get more hot.
His point is simple Zero;
a motor delivers 50Ncm of torque at 2000Kv;
a motor that does 25Ncm at 4000Kv would have the same power.
Again; i used an 8XL on my 6Kg heavy savage without ANY heat issues on 16 cells, it's beyond the power a hvmaxx is ever capable of..
