AAngel
06.14.2007, 12:36 AM
At least you have narrowed your choices down to two. My knee jerk reaction is to go with the 1400kv motor, but I like to stay on the conservative side. I'd also go with the 1400kv motor to be able to gear up rather than having to gear down on the 7S setup. On the other hand, if you go with the 1700 kv motor, you will get GREAT performance on the 7S pack and still be able to run packs with less voltage and still get good performance. From what I have seen, the 1400 kv motor doesn't even really wake up until you get to 5S voltage range. With the 1700kv motor, you'll get good performance running anything from 5S A123 on up.
I think that I just talked myself into the 1700kv motor.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.14.2007, 12:55 AM
What I want from this whole setup is to have a touch more performance than my 7XL on 5s2p, along with great efficiency (of course...)
Can you give more dirty details on how your Neu (if you think it was the 2Y) performed on 5s lipo? How heavy was your truggy? What condition was the batt pack in, etc...
I'm thinking the 1512 3D on this voltage should give roughly the same performance as the 1515/1Y does on 4s lipo, maybe a little more.
"I think that I just talked myself into the 1700kv motor." You crack me up. :005:
Was Jhautz one that got caps from you AAngel?
bdebde
That's All Folks!
bdebde's Avatar
06.14.2007, 12:58 AM
AAngel needs a few more motors to go with all them speed controls he's got. lol
zeropointbug
Z-Pinch racer
06.14.2007, 12:59 AM
Yeah, to bad they're not compatible! :005:
AAngel
06.14.2007, 01:07 AM
Bruce, right now, I have seven speed controllers and a motor for every one of them. Believe me, it's a disease. LOL.
zpb, I was running all of my equipment in my 8ight T which goes between 10 and 10.5lbs depending on what battery I'm running. The best comparison that I can make that might relay to you my impression of the 2Y's performance is this....
When running my 9XL on 4S geared 14/46, it was faster and more powerful than the 2Y on 5S geared 16/46. I suspect that the performance would have been closer if I had an 18T pinion to run with the 2Y.
When running the 9XL on 4S geared 16/46, the 2Y on 5S geared 16/46 didn't even come close. When I made this comparison, all thoughts of keeping the Neu as it was left my mind and I immediately packed it up and sent it in to Neu.
bdebde
That's All Folks!
bdebde's Avatar
06.14.2007, 01:12 AM
Yeah, I would try a Neu if they could play nice with the MM. The Quark isn't an option for me at this point, the price is too high to not have it work right from the get go (without mods). Doing the mods is not a problem, as I have no problem with smt repair and even etching circuit boards for one off projects, I just shouldn't HAVE to mod it at that price. I may just have to try a new MGM Compro so I can do a Neu (maybe, AAngel gonna be the guinea pig on that one?) for my next project. For now I will have to enjoy my little Lehner that my MM fell in love with. Lol, not trying to rub it in AAngel.
bdebde
That's All Folks!
bdebde's Avatar
06.14.2007, 01:16 AM
Yeah Tony, it is a disease, my wife is ready to put me in quarantine!
zeropointbug
Z-Pinch racer
06.14.2007, 01:17 AM
Well, I am used to (and addicted to) the 7XL on 4s, so after a few calcs, teh 3D appears like it has much promise for power.
the 2Y on 5s lipo is only roughly 24,000rpm vehicle load, no wonder you didn't see any miracles from it.
Can I get some more ppl with experience with Neu's here! please, I beg you! :002:
bdebde
That's All Folks!
bdebde's Avatar
06.14.2007, 01:21 AM
ZPB, sorry for the no Neu experiences. I do like the 7XL on 4s as well, except the heat!
zeropointbug
Z-Pinch racer
06.14.2007, 01:25 AM
Me too, but the temps I got are relatively mild (65- 70) but that was almost 2 months ago now when it was ~15c outside, so the temp will only go up. I just want a better motor.
AAngel
06.14.2007, 01:27 AM
Bruce, you have your setup. I wouldn't even be looking to something else. The Neu that I bought was a real impulse buy. I found it on sale and before I knew it, I had spent the money.
If I was smart, I would have just sold the Compro and Quark and taken the money and put it down on a Lehner 1940/9 hi amp. I would have had to run my Feigaos for a while longer, but then again, guess what I'm running now after having bought all of the high priced stuff.
zpb, I wish I could run that 7XL. I just can't do it. It has to be the weather down here. No matter what gearing I run, the motor gets to 200*F.
After taking some advise, I went and regeared my 9XL to a point where my Quark started cogging (18/46) and the motor temps are still up there. BTW, it was over 100*F down here today. It's funny because it rained a bit. You'd think that the rain would cool things off, but it doesn't. It just makes steam.
bdebde
That's All Folks!
bdebde's Avatar
06.14.2007, 01:29 AM
The difference with a more efficient motor is just amazing.
AAngel
06.14.2007, 01:31 AM
Oh, I also pulled the Quark out of my truggy today. Since I have to run the Feigao anyway, I decided to stick with the MM. It runs cooler and I'm not as worried about blowing it up. Besides that, I went out to the track again and I'll be darned if the MM wasn't better for me on the track. It was just less abrupt coming out of the turns. I suppose that I'll just have to play around with the Quark settings a bit more.
bdebde
That's All Folks!
bdebde's Avatar
06.14.2007, 01:35 AM
Yeah Tony, I am quite happy with the buggy now, just thinking ahead to the next project. I am getting the itch for a big truck. Not sure if I wanna go truggy or monster truck yet. Probably a winter project though. Got a little fine tuning to do on the buggy yet and get some racing in. Have to just about start from scratch on the suspension after losing so much weight.
zeropointbug
Z-Pinch racer
06.14.2007, 01:38 AM
Yeah, 70c is almost 160F, it was smoking hot to the hand though, I can't even imagine what 200F would be like...hot. :eek:
That is strange how you are having trouble with the Quark being 'abrupt', that is just excuse my language, @$$ backwards as far as my experience and many others here. weird, you are, hmmm, yes (my friend Yoda says)
It just occurred to me, I have to take into account the gearing range I will want to use, with the fins sticking there and everything....
