Setting Gear Mesh?
e-maxxking
Setting Gear Mesh? - 05.14.2007, 11:41 PM
How do you properly set the gear mesh? I already chewed up a spur!
BlackedOutREVO
05.15.2007, 12:06 AM
take a piece of lined paper and put it inbtween the spur and pinion and jm it down tight and tighten the screws.... then u should have a perfect mesh
05.15.2007, 12:43 AM
Sometimes, it's not a static mesh that the issue. You can have a perfect mesh when the truck is standing still, but if the motor mount flexes with jumps or whatever, the mesh will be affected. A solid, consistent is VERY important to the life of any spur. What kind of motor mount setup do you have?
Serum
Serum's Avatar
05.15.2007, 01:43 AM
Another thing to consider is that most spurgears have got an off-centre hole in them. The paper trick works in an ideal world, but with an off-centre hole the paper needs to be on the place where the gears are as close as possible.
E-Maxx King
05.15.2007, 03:11 PM
Just the stock titans with 7-cell IB4200 WCE Batteries
Serum
Serum's Avatar
05.15.2007, 03:39 PM
Can you please stick to one account? or use one only? this is rather confusing.. :)
jdtmaxx
06.18.2007, 12:16 PM
put a thin piece of paper between the gears and push them together. then tighten it up.
