06.19.2007, 08:02 PM
Well, were you running dual packs? Is it even remotely possible that you had them in parallel instead of series? Not trying to insult your intelligence, just trying to find a reasonable explanation. Assuming the motor is ok, the only factors that would make a motor run too slow would be a faulty/misprogrammed ESC or low battery voltage, and maybe the EPA settings on the transmitter.
