skellyo
skellyo's Avatar
06.20.2007, 11:42 PM
Sounds like you're undergeared a bit...a taller pinion of a tooth or two should lower the motor temp and bump up the ESC temp a little. However, if you're happy with the power, the temps are well within normal ranges.
