05.26.2007, 01:37 PM
everything worked without any issues.
removed the fan and was running whole day without it (about 2 hours on track)
it was over 30C and not a single thermal shutdown
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
05.27.2007, 01:05 AM
Thats great that you didn't get a thermal all day. Were you able to take some video there?
05.27.2007, 03:46 AM
video from normal camcorder is on its way. hopefully in few days
Radek
*EX-10 Eurus*
05.28.2007, 05:05 PM
will get the video on DVD coming saturday so expect it on sunday - right now it has 3GB
Radek
*EX-10 Eurus*
05.28.2007, 07:56 PM
i have a couple of questions for you
1.) are you using 1/8 diffs and if so what size dogbones are you using for the front and rear that conect the diff cups to the transmission.
2.) what neu are you using
3.) what did you do to you quark to keep it from thermaling.
4.) how is the cg with that chassis
5.) do those shocks have nuts on the piston shaft to keep the shock rings from comming off or is there just e-clips
6.) how many cells are you running nimah or lipo
7.) what weight shock oil are you running
thanks nice ride BTW
05.29.2007, 02:10 AM
1 - yes 1/8 diffs with custom size dogbones from Mike - 65mm front and 101mm for rear (105 would fit well the 101 has more play but works without issues just my lousy measurement)
2-1512/2.5d 2000kv
3- BrianG epoxy mod - seems to work great
4- same as with the original one but I use fullforce RC sway bars and it handles great on the track
5 - nuts
6 - 16 nimh IB4200 team corally
7 - 60WT red UE springs in front and blue in the rear still need some testing but I am quite happy with it.
Radek
*EX-10 Eurus*
06.21.2007, 04:05 PM
Radek
*EX-10 Eurus*
06.21.2007, 04:13 PM
Looks familiar! all you need is a set of aluminum knuckles (or RPM) to prevent the pillow balls from popping out.
06.21.2007, 04:16 PM
I'd go with either the Rdlogics or RPM knuckles, depending on your preference to metal or plastic. It is looking rather nice I must agree.
06.21.2007, 04:42 PM
I want knuckles for larger outer bearings so Integy EVO3 or RD racing are an option.
I dont know if I want RPM knuckles again as they look really beaten up after half a year in maxx
Radek
*EX-10 Eurus*
06.21.2007, 05:06 PM
Looks really good. I prefer RPM just because their plastic flex's more so the pillow ball is less likely to pop off.
06.21.2007, 11:38 PM
please help me out. If those are hybrids with buggy/truggy diffs, what size cvds are you running (i am aware that the trans is backwards).
06.22.2007, 02:31 AM
it does not matter the tranny is backwards :)
I have CUSTOM lenght CVDs made by Mike
Rear FLM can fit after some dremmel care but no chance for fronT MIP that I used to use. I had a temporraty solution while waiting for Mikes CVDs - I rased the tranny by 8mm therefore increasing the angle for CVDs and therefore lenght needed
Radek
*EX-10 Eurus*
06.22.2007, 09:50 AM
sorry man i realized i already asked you that question. how much play is there in the front also do you think a 100.5mmdogbone would fit or would it be to small. could i get a pic of how tight/lose the dogbones are for the front and rear. thanks.
06.22.2007, 01:13 PM
ok I have 65 mm front and 100.5 rear
the rear if pushed to one cup has pin in the middle of the other cup
the front if pushed is 3/4 in the other cup
so the rear has bit more play but works without any problems
- did have some fun at work in underground parking. (video http://www.radeks.net/?p=66)
was running quite hard and even chassis around quark heatsink was warm :) so cooling works even without fan
got 15 minutes of runtime from IB4200 charged in the morning
Radek
*EX-10 Eurus*
