Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Serum
Serum's Avatar
06.23.2007, 04:07 AM
Sounds like Robin made his holes with a reamer, if the guy did a good job by centering the two holes (aligning them parallel) it should be no problem (if the holes are a good tight/loose fit for the bearing). perhaps he told you he used a drill, but he used something different.
a drill has 2 cutting flanges, and an adjustable reamer has got many more. a drill has got the tendency to make triangle holes instead of perfect round ones.
I just checked a new racer-X I've got here; the front knuckles are 16.00 mm, and the rear knuckles are 15.98 mm
Typical size for a 16mm OD bearing is 15.97.
