crazyjr
crazyjr's Avatar
06.23.2007, 12:24 PM
But if you look at the winds, the less turns the less wire overall. There may be more strands in the turn, but less wire overall, less resistence. I think the lower resistence will allow more energy but create higher KV, so will move the peaks up in the powerband. I'm sorry, but i can't see a 7700 having the exact same peak ratings as a 4600. The numbers may be the same, but at different RPM
